Last updated on January 21st, 2026 at 11:33 am
Arduino simulators can be a great start for those who want to learn the basics of Arduino programming, circuits, and schematics design. Simulators are simple computer programs that can mimic real-world scenarios in a virtual environment, and with the help of an Arduino simulator, it’s possible for anyone (both beginners and professionals) to learn to program and test their ideas without investing money on actual hardware.
List of best Arduino simulators (online and offline)
The table given below lists the 10 best Arduino simulators, 6 online and 5 offline.
| Offline Simulators | Online Simulators | ||
| 1 | Proteus | 6 | Tinkercad |
| 2 | SimulIDE | 7 | PICSIMLAB |
| 3 | UNOArdusim | 6 | WOKWI |
| 4 | Arduino IO Simulator | 9 | Microsoft Maker Code |
| 5 | Paulware Arduino Simulator | 10 | Virtualbreadboard |
| 11 | Crumb |
Note: Only Proteus and Crumb are paid simulators. All other Arduino simulators are free to use
Online simulators
As the name implies, online simulators run in your web browser and do not require installation. They can be accessed from anywhere with an internet connection, and you don’t need to download or install any software on your system, but on the flip side, there won’t be as many features as offline simulators have.
Tinkercad
Tinkercad is a free browser-based 3D modeling tool that also lets you simulate electronic circuits in its electronic simulator called Tinkercad Circuits. In TinkerCad circuits, you can place components to build virtual circuits.
It supports block programming language, so you can just drag and drop block functions to write your code. But if you want to write your own code for Arduino, Tinkercad also has an option for that.
One of the handy features in Tinkercad is the debugger. It lets you run your program step by step while showing the updated values of your variables. There’s also a built-in serial monitor that displays data when you use serial commands, making it easy to test and troubleshoot your code.
Besides the breadboard layout, you can also view your project in schematic mode, where it’s displayed as a clear circuit diagram using electronic symbols for each component.
If you are a complete beginner, then the guided tutorials and a large library of projects will help you in your learning journey along the way.
Pros
- It has an easy user interface that makes the project-building process interesting.
- The software is free to use, making it accessible to all hobbyists.
- With this, you can also program with code blocks.
Cons
- It has a limited number of components.
- It is not suitable for users who wish to design more complex projects.
Pricing
- Free to use.
PICSIMLAB
PICSimLab (Programmable IC Simulator Laboratory) is a simulator that allows you to work with various development boards, such as Arduino, Blue Pill (STM32 based), McLab1 (PIC-based), etc.
This simulator is not as fancy and interactive as Tinkercad, but it is an ideal option for someone who just wants to simulate their project with high level of control.
PICSimLab supports a wide variety of hardware modules and oscilloscopes that you can add to your workspace throughthe Modules section.
Coding for Arduino is done outside PICSimLab, typically in the Arduino IDE or another development environment, to create a .hex file.
Pros
- Easy-to-use user interface with an online and offline version.
- Availability of sensors like accelerometers, pressure, different LCDs, etc
- Suitable for beginners.
- PICSIMLAB offers real-time simulation, which allows you to see the results of your code in real time.
- Works on Windows, MAC, and Linux.
Cons
- PICSIMLAB may not have all the components that you need to test your project.
- Small online community.
- This tool does not have the option to add an external library.
Pricing
- Free software tool
Check also: 11 Free Online Circuit Simulators
WOKWI
WOKWI is another web-based simulation that you can use to simulate Arduino projects. It has a lot of unique features that make it stand out from the other simulators, like it has support for both Arduino UNO and Mega boards.
This is a very versatile simulator, so it also has support for Raspberry Pi Pico. Additionally, the platform enables users to simulate network-based protocols such as MQTT, HTTP, and NTP, among others.
The component library is very large and even has some special parts like different types of displays, a microSD card, and a custom chip. You can program this chip by writing simple code and set what its inputs and outputs will do. This feature is great because it lets you create your own parts if you need something that isn’t already available.
It supports Arduino C/C++ code. You can write or paste sketches directly into it, and the simulator compiles them instantly. When you click Start Simulation, Wokwi uploads your code to the virtual board and runs it in real time. One issue that you could face is that sometimes, even a simple project might take a while to compile and finish running.
The platform also provides a logic analyzer. It records all the pin data and when you stop the simulation, it downloads a file with the recorded samples to your computer. Projects can be saved online and shared with a simple link. You will require a paid plan to access features like private projects or advanced cloud options.
Pros
- Wokwi is a free online microcontroller simulator that is easy to use with a diverse selection of components.
- It supports various displays like TFT, OLED, 16×2 LCD, etc.
- As Wokwi is a web-based tool, it can be accessed from Windows, Mac, and Linux. You can access your projects from any device with an internet connection.
- This tool offers a wide range of features, including a library of components, a simulator, and a debugger.
Cons
- Wokwi is a cloud-based simulator, so it can be slow at times, especially if you are using a large project or if there is a lot of traffic on the Wokwi servers.
- Wokwi is still under development, so there are occasional bugs that can cause problems.
- It can be difficult to use. The interface can be a bit clunky and confusing, especially for beginners.
Pricing
- Free to use
Maker code is another web-based tool built by Microsoft to stimulate your hardware circuit and code. It has a drag and drop based coding interface to create programs.
What makes this simulator unique compared to other simulators is its support for Adafruit, SparkFun, NRF, Sensors, Servos, and more.
You can program Arduino using Javascript as well as Python. So if you are a programming nerd and love JS, you will have a familiar interface working with this.
Pros
- Offers a simple drag-and-drop interface that makes it easy for beginners to get started with coding.
- It supports a variety of hardware platforms, including Arduino, Sparkfun, Jacdac, Adafruit, and Sparkfun boards.
- Available for free, and you can use it without signing up.
Cons
- The platform doesn’t have a wide variety of peripherals to experiment with.
- Doesn’t support C programming.
Pricing
- Free.
Virtualbreadboard
Virtualbreadboard is the most interesting Arduino simulator on our list because it’s a Windows store app, and you need to download it to work with it. This app has a very user-friendly interface, and you can easily design your circuit by dragging and dropping your design.
This nifty tool supports HEX code. So compile your code from Arduino IDE, Arduino Create, PlatformIO, and Visual Studio, and upload it directly to this tool.
Pros
- Build hybrid applications using Virtual Components as a user interface.
- Virtual Components work with your physical microcontroller via the EDGEY interface.
- The EDGEY interface supports LiquidCrystal, OLED SSD1306, Nonpixel, MAX7219, Epaper, DSO, and Servo.
- It also has Unit Test capabilities for your circuit.
Cons
- Like any complex software, VirtualBreadboard has a learning curve. Users need to spend time familiarizing themselves with the interface.
- This tool is resource-intensive, requiring a powerful computer to run smoothly.
Pricing
- Free to use Tool.
Crumb
Now, many of you might not have heard of this simulator—it’s called CRUMB. It created quite a buzz when it was first launched. What sets this simulator apart is its visual, engaging environment that mimics the feel of building circuits on a real breadboard.
Yes, instead of prototyping a circuit in 2D, here you get a 3D environment, building circuits in a real-like breadboard, complete with jumper wires, and other active and passive components.
This simulator is available for Windows and macOS through Steam, and it’s also available on the App Store. Although it’s a paid tool, it’s quite affordable—priced at around $9.
To start building a circuit, you have to first place a breadboard on the workspace. CRUMB currently supports only the Arduino Nano as the microcontroller, but the 3D environment makes designing and viewing your projects more interactive than a flat 2D view.
When you click on the Nano, there is an option to open the built-in code editor. It works much like the Arduino IDE, letting you write and upload sketches to the virtual board and view the output in the Serial Monitor.
For powering your circuit, there is a 12V signal generator for AC circuits and a 12V power supply for DC circuits.
Once your circuit is ready and running in Crumb, you can do much more than just watch it work. The simulator gives you live feedback by highlighting voltage levels on the components, so you can instantly see how power flows through the circuit.
You can also open the built-in scope to view real-time graphs of voltage or current on any part of the setup, which makes it easier to understand how the circuit behaves. The settings icon on the top right lets you change the simulation frequency, while to change
Best offline Arduino simulators
An offline Arduino simulator needs to be installed on your PC before you can work with it. Let’s start with Proteus by Labcentre.
Proteus
The first Arduino simulator for PC on our list is Proteus Design Suite because its time tested, and it has essentially everything you need to design a circuit, whether it is complex or simple. And it has support for Arduino as well.
The circuit can be put under test by using different features like a transient response, DC sweep, etc, provided in the software. After you are done with the simulation and testing, you can make a PCB out of the schematic.
Pros
- User-friendly interface with powerful simulation tools with microcontroller support along with a 3D viewer for PCB.
- Rapid testing tools like DC swipe and transient response
- Huge built-in parts libraries
- Customizable and self-made parts library options.
Cons
- Expensive compared to some other tools.
- Limited compatibility with some third-party tools and libraries
- With large circuits, users may experience performance issues.
- Very costly
Latest pricing
- Standard Feature Set – $537.00
- Professional Feature Set – $1692.00
- Proteus Enterprise Edition – $6972.00
- Proteus Platinum Edition – $8622.00
- Custom – $248.00
SimulIDE
SimulIDE is another offline simulator available to the community. It is not as powerful as Proteus, but if you are just starting, then this can be a great option.
This simulator is easy to use and will help you lay the foundation in electronics. You can simply drag and drop components into the workspace, connect them, and get your project running in just a few steps.
SimulIDE offers a wide range of components including inputs, outputs, power sources, and different microcontrollers. For Arduino, it has the Uno, Nano, Mega, and Duemilanove boards to simulate the circuits.
Apart from Arduino, it also supports PIC, NXP, and other microcontrollers. Other key features of this simulator include the built-in components like an oscilloscope, wave generator, and more.
Pros
- Easy-to-use interface with a wide range of analog and digital parts.
- Supports popular microcontroller platforms like PIC, AVR, and Arduino
- Built-in code editor for GcBasic, Arduino, PIC ASM, and AVR ASM
- Debugger with breakpoints, watch registers, and global variables.
- Signal visualization and signal plotter for real-time signal analysis
- This tool is designed to work on Windows, MAC, and Linux.
Cons
- Not suitable for advanced circuit analysis.
- Limited features and component library.
- Limited community support and online resources.
- Simple and not very accurate electronic models.
Pricing
- Free and Open Source
Must read: 10 Best Circuit Simulation Software (Free and Paid)
These were some of the best offline simulators for Arduino, and in the rest of the article, we’ll be discussing online simulators.
UNOArdusim
UNOArdusim is another open-source simulation software that is freely available for download. This simple tool is written by Professor Simmons of Queen’s University, Canada.
When it comes to hardware support, it can do a lot more compared to other simulators. It has support for peripherals, gear motors, stepper motors, and servo-motors.
Additionally, users can also debug their code and see how it runs, as well as view pin voltage and waveforms. If you’re just getting started with Arduino, the UNOArdusim is a great tool for experiments.
This simulator only supports some limited libraries that are listed here. Other third-party or unsupported libraries will not work because of unrecognized directives or missing files. Execution timing is not modeled precisely at the instruction level, so you often need to use delay in loops to synchronize pin-level changes with what you expect to see. Also, function calls made through user-declared function pointers are not supported.
Pros
- It’s free and open-source, so you can contribute to its development or modify it to suit your needs.
- UnoArduSim supports a wide range of Arduino features, including interrupts, timers, and various communication protocols.
Cons
- This simulator is unable to simulate Arduino’s analog-to-digital converter (ADC) or the real-time clock (RTC).
- UnoArduSim is a powerful tool, but it can be difficult to learn how to use it.
- This is a simulation, so it’s not as fast as a physical Arduino board.
- Runs only on Windows.
Pricing
- Free Educational tool for everyone to use.
The Arduino IO Simulator is very similar to UNOArdusim because it is also designed to simulate only the Arduino board. One additional thing about this software is that it has support for MAC OS. This software allows you to control servos, seven-segment displays, LCD timers, and I/O pins.
The Arduino IO sim can be a great tool for a beginner who just wants to start out, but in terms of features, it has a lot of room for improvement.
Pros
- Easy to use.
- Available for both Windows and Mac.
Cons
- Not suitable for intermediate and advanced users because the simulation environment is not that powerful.
Pricing
- Free and open-source software tool
Pauls Arduino Simulator
Pauls Arduino Simulator is another free and open-source Arduino simulator that helps you to test your Arduino sketches in a simple manner. This simulator is created by Richard Paul and is completely written in C++. It includes LEDs and LCDs, a 4х4 keypad matrix, a rotary DIP switch, etc.
The installation video on Paul’s YouTube channel explains how to install the simulator using Dev-C++ and how to use the simulator after that. For further instructions, you can check his GitHub. To download the CPP compiler, you can check out SourceForge.
Pros
- This tool has support for LED, 7-segment displays, keypads, and LCD displays, among others.
- Allows you to add breakpoints in your code so it is easier to debug and test your Arduino projects.
- Includes a SimUtilities class that contains various utilities for listing connections and setting values on the connection.
- Supports the use of pull-up resistors using the pinMode and digitalWrite functions
- Uses actual Arduino libraries such as Keypad.cpp
- Available for Windows.
Cons
- Requires installation of a separate development environment (Orwell Dev-C++) to run the simulator.
- Limited support for certain Arduino libraries, which may require modification of the code.
- Lack of community support.
- The SimUtilities class may not be comprehensive enough for more complex projects.
Pricing
These were some of the best offline simulators, and for the rest of the article, we’ll be discussing online simulators.
Arduino simulators are a great tool for testing out your project before making an actual circuit. As per our research WOKWI, and Tinkercad are the best online Arduino simulators. And Proteus and SimulIDE are the two best offline simulators.
What would be great is to have a program that I can use on my phone like some of the other programs where you don’t have to download something but have a complete list of the most common used parts and then have them accessible to that program when it comes to the programming of these boards or components that should be a request made to each one of the companie making the program the company will have time to research and if possible install the program for that component or components and then the companies that make the products can add any other programs that they may have for that bored or components.
Very very helpful
Thank you writter.
