What Are The Best ESP32 Kits in 2026 ? Our Top 3 Picks
Last updated on January 5th, 2026 at 12:36 pm
ESP32 is a cheap microcontroller that comes with integrated Wi-Fi and Bluetooth technologies. It is quite notable amongst electronics engineers and hobbyists. If you want to make your own ESP32 projects you should consider buying an ESP32 kit.
It will save you money and you can get all the pieces in a single place. To make it easier for you we have compiled a list of ESP32 kits that are most useful.
Our recommendations on ESP32 Kits“:
Freenove ultimate starter kit for ESP32-WROVER
Freenove Ultimate Starter Kit for ESP32 CAM…
  • ESP32 WROVER -> A powerful and small controller with onboard camera and wireless. (Included in this kit.)
  • 3 programming languages -> MicroPython, C and Processing (Java).
The Freenove Ultimate Starter Kit is one of the best kits for ESP32 that you can buy. It comes with 12 sensors and modules. These include an LED display, a DHT11 temperature and humidity sensor, a light sensor, a soil moisture sensor, and more. The kit also comes with a detailed tutorial that will help you get started with ESP32 programming.
  • It comes with a 777-page long detailed tutorial including code examples and circuit diagrams
  • The board has an onboard camera connector for easy interface.
  • Gpio extension module is also available.
  • The provides complete technical and customer support to all its buyers
  • The kit comes in a plastic box which makes storage of components hassle-free
What’s included?
  • Sensors: 7
  • Display: 4
  • Input devices: Joystick, buttons, etc.
  • Motor: 3 Types( Stepper, Servo, DC)
  • Breadboard: Yes
  • Box: Yes
  • The only way you can get the supporting material is by downloading it; there is no printed manual supplied with the kit.
  • This kit is not recommended for beginners, as the troubleshooting guidelines are very vague.
Freenove basic starter kit for ESP32
Freenove Basic Starter Kit for ESP32-WROVER…
  • ESP32-WROVER -> A powerful and small controller with onboard camera and wireless. (Included in this kit.)
  • 2 programming languages -> MicroPython and C.
This kit is a smaller version of the Freenove Ultimate Starter Kit for ESP32-WROVER. It has a few components to get you started. This kit is very beginner-friendly.
  • The kit comes with a 401-page tutorial manual.
  • A programming cable is included in the kit
  • The kit includes a GPIO extension board which is not available in other kits of similar price.
What’s included?
  • Sensors: 0
  • Display: 0
  • Motor: 0
  • Breadboard: Yes
  • Box: Yes
  • The provided manual was written a few years back and now seems a little outdated
  • Not a single sensor in the kit.
Freenove 4WD Car Kit for ESP32
FREENOVE 4WD Car Kit for ESP32 CAM (Included),…
  • Multiple Functions: This car has four drive wheels, the rotatable head has a camera and a dot matrixe module (Assembly required) (Battery NOT included)
  • ESP32 WROVER: Dual-core 32-bit microprocessor up to 240 MHz, 4 MB Flash, 8 MB PSRAM, onboard 2.4 GHz Wi-Fi and Bluetooth 4.2 (LE), camera
This ESP32 kit is specifically designed to build an ESP32-based remote-control car. If robotics fascinates you then go buy this kit right now. It might be a little complex for beginners but it is perfect for hobbyists and advanced makers.
  • A comprehensive, online guide is available that shows users how to utilize all aspects of the kit and provides a detailed explanation of the accompanying code.
  • The remote control provided with the kit will enable you to operate your newly built car, but you can also use other devices such as phones, tablets, and computers.
  • You can program this car to perform various tasks such as obstacle avoidance, line Tracking, and light Tracing
  • You can easily upgrade the car by doing modifications of your own. Components are available online for purchase.
  • The kit does not provide batteries for the car
  • The range of the remote control is only 1 meter, so you have to stay extremely close to the car for it to work
Conclusion – Best ESP32 kits
This board is known for its wide range of applications. It is used worldwide by makers in several projects. With the help of these kits, you can get a taste of the wide range of applications and decide if that is something you would like to explore more.
ESP32 kits are the best way to learn application-based programming. If you ask us to pick one then we might suggest you Freenove Ultimate Starter Kit for ESP32-WROVER.
Kanishk Godiyal
