Last updated on January 6th, 2026 at 11:16 am
When it comes to measuring electrical quantities and testing electronic appliances, a multimeter is a great tool. However, the electronic market is flooded with various options, and as a beginner, choosing the right one can take time and effort. No need to worry; we’re here to assist.
We’ve selected among various options to bring you the top 9 multimeters for beginners. Whether you’re budget-conscious, seeking a tool for fundamental tasks, or aiming for a multimeter with capabilities for more advanced features, we’ve got you covered.
Are you a beginner? Read this step-by-step tutorial on how to use a multimeter.
What to look for in a good multimeter?
When buying your first multimeter, there are a few key things to consider:
1. Accuracy and resolution
For general use, you’ll want a multimeter with at least 0.5% accuracy and the ability to measure down to millivolts. More precision means more accurate readings, especially for low-voltage measurements.
2. Safety ratings
Look for a multimeter with at least a CAT III 600V safety rating to measure common household voltages safely. Higher safety ratings like CAT IV allow you to measure voltages at power lines and distribution panels. For beginners, CAT III is typically sufficient.
3. Auto-ranging vs. Manual ranging
Auto-ranging multimeters automatically choose the correct voltage/resistance range for you. While manual-ranging multimeters require you to select the proper range before taking a measurement. Auto-ranging is more convenient, especially when you’re still learning. But the higher cost is the downside.
4. Features
For basic testing and measurements, a multimeter that measures AC/DC voltage, current, resistance, and continuity should suffice. More advanced meters offer measurements for capacitance, frequency, temperature, and inductance. Think about how you’ll use the multimeter to determine what features you need in a multimeter.
5. Display
A large digital display with a backlight allows for easy reading. Analog multimeters with needle readouts can be more difficult to interpret. For beginners, a digital multimeter is typically the way to go.
6. Fuses
Multimeters have fuses to prevent them from overcurrent. More affordable multimeters may have non-replaceable fuses, so look for a model with fuses that can be swapped out in case the fuse is blown.
Now let’s start discussing the multimeters one by one:
9 Best Multimeters for Beginners
Here is our top pick of the best multimeter for beginners in 2025:
1. AstroAI AM33D
The number one multimeter on our list is AstroAI AM33D. It is a pocket-sized multimeter perfect for beginners. This entry-level multimeter has all the basic functions you will need, from AC/DC voltage measurement to continuity and diode testing. With data hold and backlit screen buttons, it also has a low-battery indicator.
In terms of precision, this manual ranging multimeter can display 3 ½ digits(3 full digits and 1 half digit) with 2000 counts and a sampling speed of 2 per second.
For $15, you also get a “Square wave” output function for testing square wave, CAT II safety rating, and two fuses. One fuse is for high current, and the other is for high voltages. This is rare because beginner-level multimeters usually have a single fuse.
Features
- Safety rating – CAT II
- Type- Manual ranging
- AC current function- NO
- Weight – 180g
- Dimensions- 5.1 x 2.8 x 1.4 inches
What do you get with the multimeter?
- Multimeter
- Test leads
- Built-in battery
- User manual
Pros and Cons
PROS
- Compact and portable
- Affordable price
- Low battery indicator
- Has dual fuses and a square wave output function
CONS
- Cannot measure AC current
- Max AC voltage rating is 500V. Other models have 600V
- Not suitable for high-end professional applications.
2. KAIWEETS KM601
The second multimeter on our list is the Kaiweets KM601, a smart and versatile multimeter designed for both beginners and advanced users. Its standout feature is Smart Mode, which activates by default. In this mode, the KM601 automatically measures voltage, resistance, and continuity, identifying the measurement content and selecting the optimal range for enhanced convenience and speed.
This multimeter features a rechargeable 1200mAh battery, eliminating the need for disposable batteries, and is equipped with a built-in flashlight for added functionality in dim environments. Its 3.54-inch luminous LCD color screen ensures clear readings, making it user-friendly even in low-light conditions.
Switching between Smart Mode and Manual Mode is simple. Use the “FUNC” button for manual mode and press and hold to return to smart mode. Smart mode supports testing of DC voltage, AC voltage, resistance, and continuity, while manual mode offers even greater control for specific tasks.
Precision and Safety
The KM601 boasts 10,000 counts with True-RMS functionality, ensuring accurate readings, even for non-linear loads. It adheres to IEC safety ratings CAT.III 1000V and CAT.IV 600V, with CE and RoHS certifications, double fuses, and overload protection to safeguard against burns and mishaps.
Additional features
- LED lightning jacks: The jacks intelligently light up to guide you in inserting the test leads correctly, making it ideal for beginners.
- Portable design: At just 6.5 inches, it is compact and easy to carry.
The KAIWEETS KM601 is a fantastic choice for beginners due to its versatility. It comes with a luminous LCD color screen, offering you easy reading in dim places. Additionally, it has a user-friendly interface that accurately measures 10A current, AC/DC current, and AC/DC voltage.
Features
- Safety rating: CAT.III 1000V, CAT.IV 600V
- Type: Auto-ranging with Smart Mode
- True-RMS meter: Yes (10,000 counts)
- Weight: Not specified
- Dimensions: 6.5 inches in length
- Display: 3.54-inch luminous LCD
- Multimeter
- Test leads
- Built-in rechargeable battery
- USB charging cable
- User manual
PROS
- Accurate and reliable measurements.
- User-friendly interface.
- Durable build quality.
- Great value for the price.
CONS
- Some users may find it a bit bulky.
3. AstroAI WH5000A(DM6000AR)
The AstroAI WH5000A takes the third spot on our list with its professional-grade features and ease of use. This auto-ranging multimeter is equipped with True RMS functionality, making it capable of measuring both AC current and voltage with high accuracy.
Its design focuses on convenience, with features like auto shut-off, a hanging magnet, and a kickstand, simplifying hands-free operation during measurements. The LCD screen with a backlight ensures clear visibility in low-light conditions, while the hold function lets you lock readings for convenience.
Safety is a priority with the AstroAI WH5000A. It meets CAT II and CAT III safety standards and features double ceramic fuses for protection against overloads and burns. These explosion-proof fuses (F400mA/600V and F10A/600V) enhance reliability and durability. Additionally, a rubber sleeve protects the multimeter from shocks and falls.
Advanced features
This multimeter includes advanced functions such as:
- Temperature measurement for thermocouple readings.
- Capacitance testing, ideal for measuring capacitors.
- Frequency and duty cycle measurement, adding versatility for electronic circuit testing.
- A multifunctional socket for additional test options.
The AstroAI WH5000A is an excellent multimeter for beginners and veterans in the electronic industry. It comes with great features, allowing you to use it for many years to come. One of its unique capabilities is its ability to measure temperatures in overheating electronics.
PROS
- Accurate and reliable.
- Versatile for various electrical tasks.
- Excellent build quality.
- Good value for the features offered.
CONS
- It’s slightly more expensive than some other beginner models.
4. INNOVA – 3320
The INNOVA 3320 is a compact, user-friendly, and versatile multimeter designed to make testing simple and convenient. Its auto-ranging feature automatically selects the correct measurement range, eliminating the need for manual adjustments and making it perfect for beginners.
This multimeter is UL listed, ensuring safety and quality, while its auto shut-off feature helps conserve battery life by turning the device off when not in use.
The INNOVA 3320 includes a built-in stand and wrist strap, allowing hands-free operation for tasks that require precision or extended testing periods. This design feature makes it especially practical for users working in tight or awkward spaces.
One of the standout features of this multimeter is its small battery load test function. The color-coded LEDs make it easy to check the charge status of batteries, offering quick and clear results for common household or automotive batteries.
The INNOVA 3320 is an excellent multimeter from a top-notch company, Innova. This device comes with a unique battery load test option. Further, it is well-designed from quality materials, guaranteeing you the best performance.
Additional features
- Compact Design: Lightweight and portable, making it easy to carry and store.
- Durability: Built to withstand everyday use, perfect for home and automotive applications.
Whether you need a basic multimeter for home use or occasional automotive diagnostics, the INNOVA 3320 is a reliable and affordable option that balances simplicity and functionality.
Features
- Safety: UL listed
- Battery testing: Color-coded LED indicators
- Hands-free operation: Built-in stand and wrist strap
- Auto shut-off: Yes
- Dimensions: Not specified
- Multimeter
- Wrist strap
- User manual
PROS
- Great for automotive use.
- Clear and easy-to-read display.
- Sturdy construction.
- Affordable pricing.
CONS
- Limited features for non-automotive electrical work.
5. Klein Tools MM400
The Klein Tools MM400 is a robust and reliable multimeter designed for professionals and DIY enthusiasts. Its durable construction allows it to withstand a 3.3-foot (1-meter) drop, making it ideal for demanding job sites where wear and tear are common. Additionally, the low battery indicator and easily accessible battery compartment ensure seamless operation without unnecessary delays.
Comprehensive testing capabilities:
This multimeter is packed with versatile features, including:
- AC/DC current and voltage measurement
- Resistance measurement
- Temperature testing with a thermocouple
- Capacitance, frequency, and duty cycle measurements
- Diode and continuity testing
Its auto-ranging capability and 4000-count LCD screen provide accurate and clear readings, ensuring precision across a wide range of tasks.
Certified to CAT III 600V and CE standards, the Klein Tools MM400 is built with safety in mind, making it suitable for both home and professional use.
With its rugged design, advanced testing functions, and user-friendly features, the Klein Tools MM400 is perfect for both fieldwork and home projects. The inclusion of essential accessories like test leads, a thermocouple with an adapter, batteries, and a user manual ensures you’re ready to work right out of the box.
Features
- Safety rating: CAT III 600V; CE Certified
- Temperature measurement: Yes (thermocouple included)
- Additional testing: Capacitance, frequency, duty cycle, diode, and continuity
- Drop protection: Yes (3.3-foot drop)
- Display: 4000-count LCD
- Dimensions: 6.00 inches (15.2 cm x 4.5 cm x 8 cm)
- Multimeter
- Test leads
- Thermocouple with adapter
- Batteries
- User manual
PROS
- Exceptional build quality
- Accurate readings
- Suitable for various professional applications.
- A magnetic hanger is a handy addition
CONS
- Pricier compared to other beginner multimeters.
6. Mastech MS8268
The Mastech MS8268 is a versatile and well-designed multimeter ideal for industrial and home applications. Known for its advanced features and user-friendly design, this multimeter offers excellent performance for both professionals and beginners.
Key features and performance
The MS8268 includes auto-ranging capabilities, which simplify operation by automatically selecting the appropriate measurement range. It is capable of measuring:
- DC voltage up to 1000V
- AC voltage up to 650V
- Its 4000-count LCD display ensures precise readings, while the low battery indicator alerts you when it’s time to replace the batteries.
With safety ratings of CAT II 1000V and CAT III 600V, the Mastech MS8268 is designed to handle industrial-grade tasks while ensuring user protection. The auto power-off feature also conserves battery life, making it both safe and energy-efficient.
The Mastech MS8268 is also another top-notch industrial testing device. It is a well-designed multimeter with excellent advanced and amazing features.
Features
- Safety rating: CAT II 1000V / CAT III 600V
- Voltage range: DC up to 1000V, AC up to 650V
- Display: 4000 counts
- Auto power-off: Yes
- Low battery indicator: Yes
Multimeter
- Test leads
- User manual
PROS
- Versatile and feature-packed.
- Good value for the money.
CONS
- The display may be small for some users.
7. Etekcity MSR-A600
The Etekcity MSR-A600 is a budget-friendly multimeter tailored for beginners, offering a blend of essential features and reliable performance. Designed with simplicity in mind, it’s perfect for users who need a straightforward multimeter for basic measurements.
This multimeter includes auto-ranging, which makes measurements quick and effortless by automatically selecting the appropriate range. The 2000-count display provides accurate readings, while features like data hold and auto shut-off improve convenience and energy efficiency during use.
Rated for CAT II 600V, the MSR-A600 offers solid protection for basic electrical tasks. The drop-protected rubber sleeve shields the multimeter from wear and tear, making it durable enough for everyday use. Additionally, the rubber sleeve includes a test lead holder for easy storage, adding to its practicality.
This multimeter is equipped with a built-in kickstand, allowing for hands-free use, and a low battery indicator to prevent unexpected downtime. Its design ensures that both beginners and experienced users can operate it effortlessly.
Features
- Safety rating: CAT II 600V
- Counts: 2000
- Additional testing: Capacitance, AC current
- Convenient features: Data hold, low battery indicator, auto shut-off, built-in kickstand
- Drop protection: Yes (rubber sleeve with test lead holder)
- Multimeter
- Test leads
- Protective rubber sleeve
- User manual
The Etekcity MSR-A600 is a budget-friendly multimeter suitable for beginners.The manufacturer, Etekcity ensures all the requirements you are searching for in any type of multimeter irrespective of your experience. The MSR-A600 is a simple multimeter with basic functionalities.
PROS
- Affordable and accessible.
- Simple to use.
- Lightweight and portable.
- Good for basic household tasks.
CONS
- Limited features for advanced electrical work.
8. HILTEX 40508(DT830B)
The Hiltex 40508 is a straightforward and budget-friendly digital multimeter, perfect for beginners and hobbyists. You must have seen this yellow multimeter in your school lab or in a YouTube video. Designed for basic electrical troubleshooting, it provides essential measurement functions in a compact and easy-to-use package.
The DT830B supports a variety of basic measurements, including:
- DC Voltage: Up to 1000V
- AC Voltage: Up to 750V
- DC Current: Up to 10A
- Resistance: Up to 2MΩ
- Diode Testing
Its 3 ½-digit LCD display ensures clear and easy-to-read results, making it ideal for simple tasks and educational use.
The multimeter features overload protection, safeguarding it against damage during operation. The low battery indicator ensures timely replacements, while the protective rubber sleeve enhances durability and provides a secure grip.
The lightweight and compact design makes the Hiltex DT830B easy to handle and store, making it a practical choice for quick and basic measurements.
Features
- Type: Manual ranging
- Safety: Overload protection
- Counts: Not specified
- Additional testing: Diode testing
- Display: 3 ½-digit LCD
- Compact design: Yes
- Multimeter
- Test leads
- 9V battery
- User manual
The HILTEX 40508 is a basic, no-frills multimeter perfect for beginners on a tight budget. You can use it at home, as a casual device, or for car diagnostics to measure resistance and voltages.
PROS
- Extremely affordable.
- Simple and easy to use.
- Compact and lightweight.
- Ideal for basic DIY projects.
CONS
- Lacks advanced features and durability.
9. EXTECH EX330
The Extech EX330 is a compact, feature-rich auto-ranging multimeter designed for both beginners and professionals. Its versatility and durability make it an excellent choice for a wide range of electrical and electronic tasks.
The EX330 stands out with its built-in non-contact AC voltage detector, adding an extra layer of safety for live wire detection. It supports advanced functions like:
- Frequency and Duty Cycle measurement
- Temperature measurements using the included Type K temperature probe, with readings available in both Fahrenheit and Celsius.
Its 4000-count LCD display ensures clear, accurate readings, while the Max Hold feature captures the highest value during measurements, and the Data Hold function freezes the display for note-taking or review.
The Extech EX330 is an exceptional all-around multimeter, combining advanced features, safety certifications, and convenient usability. Its built-in AC voltage detector and temperature measurement capability make it a standout option for both basic and advanced tasks
Features
- Counts: 4000
- Additional testing: Frequency, duty cycle, capacitance, temperature, diode, and continuity
- Built-in AC voltage detector: Yes (non-contact)
- Convenient features: Max Hold, Data Hold, Auto power-off, Relative Function
- Temperature measurement: Yes (Type K thermocouple included)
- Dimensions: 5.7 x 1.6 x 2.9 inches
- Multimeter
- Test leads
- Type K temperature probe
- Rubber holster
- Tilt stand
- Two AAA batteries
- User manual
PROS
- Feature-rich and versatile.
- Accurate measurements.
- Non-contact voltage detection enhances safety.
CONS
- Pricier compared to some other beginner models.
