5 Best RCA to HDMI Converters in 2026
Last updated on January 6th, 2026 at 11:30 am
Most older monitors used RCA connectors for transferring audio and video data. Also, some modern devices like PlayStations and Xbox, and older devices like VCRs and DVD players have an RCA connection. But many latest monitors do not have RCA ports. So to connect devices with these connectors to your latest monitor, you will need an RCA to HDMI converter.
HDMI port is the most widely used when it comes to audio and video signal transmission. It can transfer both audio and video signals through a single route. But that’s not the case with RCA connectors. It has one connecter for video transmission and another two for stereo audio transmission.
This list comprises the best RCA to HDMI converters available in the market. So you can use your RCA devices with ease.
“Our recommendation on RCA to HDMI Converter”
ABLEWE RCA to HDMI converter
Size: 2.09 in x 2.68 in x 0.79 in
Color: Black, White
This is the only adapter on our list that gives you a color option to choose from. It is a compact RCA to HDMI converter with an elegant design. It has RCA input ports on one end and an HDMI output port on the other. You can directly plug all your wires into the respective ports and start using them. It’s that hassle-free!
This has a built-in scaler that lets you select between 720P and 1080P resolution. All you have to do is switch the button to get the desired resolution. This adapter also has a Micro USB port for charging. You need to keep it plugged in while using the adapter. A Micro USB to USB 3.0 cable is provided with the adapter for charging.
Tengchi RCA to HDMI converter
Size: 5.91 in x 5.91 in x 0.71 in
Color: Black
Warranty: 12 months
RCA to HDMI converter by Tengchi has RCA ports on one end and an HDMI port on another end. You get an HDMI to HDMI cable along with the adapter. So you can either insert another HDMI connector from the screen into the adapter or use the provided cable to connect the HDMI male to the display screen.
They also provide a Micro USB cable for charging and as an additional power supply. The video transmission takes place at 720P or 1080P resolution. You can select the desired resolution on the provided switch.
Viagkiki AV to HDMI adapter
Size: 39 in x 1.57 in x 0.51 in
Color: Black
This adapter is very similar to the Tengchi RCA to HDMI Converter. It has RCA input and HDMI output. An HDMI cable is provided with the adapter to convert the female port to a male connector.
The difference between Tengchi and this adapter is that the connectors on this one have gold plating. Gold-plated connectors are stronger and more resistant to corrosion than normal ones. They also ensure enhanced performance and increased connectivity. And all of this is for the same price! This adapter also has a resolution switch to select between 720P and 1080P.
The provided Micro USB port is used for charging. The charger should be connected and kept on always while using the adapter. A Micro USB to USB 3.0 cable is also provided for charging. This has everything you need in an RCA to HDMI converter.
GINGIN RCA to HDMI converter
Size: 5.71 in x 3.54 in x 1.65 in
Color: Black
This is another compact RCA to HDMI converter from GINGIN. It comes with all the necessary cables you will require to use the adapter. But if you already have all the cables then you can opt to buy just the adapter without cables. The design is a little bit different from the ABLEWE RCA to HDMI Converter, but the functionality is almost the same.
The three ports on one end collect the RCA input, which is transformed into the HDMI output. It’s a plug-and-play adapter, so you do not need to install any external drivers. The adapter uses an intelligent chip for data conversion. That chip is responsible for signal processing and resolution scales.
Read also: 6 Best USB to Micro USB Cables
Size: 7.4 in x 5.67 in x 1.26 in
Color: Black
If you are looking for an adapter with RCA male connectors, then this is the one for you. One end of the adapter is split into three cables, one for each of the connections. The other end has an HDMI output port. You can also connect the provided HDMI cable to this port to get a male connector.
Both the RCA and HDMI connectors are plated with gold so that they stay free from corrosion and make them stronger. Gold-plated connectors participate in giving a bett performance than non-plated ones. Just like any other RCA to HDMI adapter, this also requires a charging port. So there is a Micro USB port supplied for charging.
There’s also a Micro USB to USB 3.0 cable supplied along with it. The adapter case has centralized holes that keep the air flowing and avoid heating up. The resolution selector will allow you to switch between two resolutions. So you are just a switch away from the right choice.
Conclusion – Best RCA to HDMI converters
Using a converter is the only way to display data from your device with an RCA connection to a screen having an HDMI connection. You can easily choose one from our list and continue with the important work. Using the converter is also very easy. You don’t need to have advanced knowledge to use these adapters. We are sure these connectors will help you get in touch with the data you desire.
Kanishk Godiyal
