5 Best R-Pi Pico Kits for Beginners in 2026 (Our top picks)
Last updated on January 5th, 2026 at 12:36 pm
Raspberry Pi Pico is built using the flagship microcontroller chip RP2040. It is used for simpler tasks unlike the Raspberry Pi 4 which can run an entire OS. Now if you are planning to buy a Pico, you might need various devices and sensors to start with. Buying these components separately takes a lot of time, planning, and more money!
So to save you time and money, our team has compiled the best 5 R-Pi Pico Kits available online. Take a look:
Our top picks on R-Pi pico kits“:
Which is the overall best kit?
The overall best Raspberry Pi Pico kit is the SunFounder Raspberry Pi Pico Ultimate Starter Kit . There are a total of 320 components in this kit that will keep you busy for a long time. So this is an ideal kit for beginners as well as experts. It is priced at around $59 which is a good deal considering its detailed online tutorial book and components variety.
SunFounder Raspberry Pi Pico ultimate starter Kit
SunFounder Raspberry Pi Pico Ultimate Starter Kit…
  • 【Ultimate Starter Kit for Raspberry Pi Pico】Contains over 320 items and 113 online projects for all Arduino and Raspberry Pi users, from beginners to advanced programmers
  • The kit provides you with an online booklet that has 113 project tutorials with operating principles, circuit diagrams, datasheets, and an explanation of code. 59 MicroPython lessons, 38 lessons in C/C++, and 16 lessons in Piper Make.
  • There are a total of 320 components in this kit. No other kit has this many components.
  • You also get a breadboard power module and an esp8266 chip that you can use to create IoT projects.
  • Lots of passive components like resistors, capacitors, etc. Can help you learn electronics as well.
What’s included?
  • Sensors: 12
  • Display: 4
  • Input devices: Joystick, buttons, etc.
  • Motor: 3 Types( Stepper motor is not included)
  • Breadboard: Yes
  • Box: Yes
  • If you are an absolute beginner you might find navigating the kit a bit difficult merely with the help of a manual given online
Freenove Ultimate Starter Kit for Raspberry Pi Pico
Freenove Ultimate Starter Kit for Raspberry Pi Pico (Included), Dual-core Arm Cortex-M0+…
  • Raspberry Pi Pico: A tiny, fast, and versatile board built using dual-core Arm Cortex-M0+ processor
  • 3 Sets of Codes: MicroPython, C and Java (Java codes run on computers to provide graphical interfaces)
The colorful images in the tutorial and code explanations will help you move smoothly through the kit.
  • There are a total of 222 items inside this kit.
  • This is the only kit on this list that has separate tutorial books for Arduino IDE and Micropython. Arduino IDE tutorial book is 260 pages long whereas Micropython one is 300 pages.
  • So even if you are an absolute beginner, this kit will guide you from the very start.
  • Some processing projects using JAVA are also given in the tutorial book.
  • Has 3 perf boards for soldering projects and one breadboard power module.
What’s included?
  • Sensors: 7
  • Display: 3
  • Motor: 3 Types( With Stepper motor)
  • Breadboard: Yes
  • Box: Yes
  • Few sensors at this price.
  • Little explanation is provided about working principles which can be hard for beginners
GeeekPi raspberry pi pico Basic Starter Kit
GeeekPi Basic Starter Kit for Raspberry Pi Pico, with…
  • This is a basic starter kit for you to learn Embedded programming, hardware and electronic circuits smoothly and quickly in a computer.
Get started with Python programming with this amazing Raspberry Pi Pico kit. It is ideal for beginners and software engineers. Learn to operate and integrate each component to form a final product. Make your microcontroller projects with C/C++ and MicroPython.
  • The only kit with an offline tutorial book along with links to detailed video tutorials. There are 100 pages in the book and 20 projects.
  • The star components of this kit are I2C 1602 LCD Display Module, PIR sensor, and the 9g Mirco Servo Pack
What’s included in the kit?
  • Sensors: 1
  • Display: 1 x LCD and 4 x Led Matrix
  • Input devices:
  • Motor: 1 ( Servo)
  • Breadboard: Yes but half-size
  • Box: Yes
  • The book provided with the kit is only of minor help as a detailed explanation is not provided in it.
  • Fewer components at this price.
  • The header pins are not pre-soldered. So you will have to manually solder the pins.
SunFounder Raspberry Pi Pico starter kit
SunFounder Starter Kit for Raspberry Pi Pico with…
  • 【Starter Kit for Raspberry Pi Pico】SunFounder Basic Starter Kit for Raspberry Pi Pico is One-Stop-Shop for Raspberry Pi Arduino Beginners & Experts. Online tutorials provide you with step-by-step guidance, with 283 items and 40 projects
This is the second kit by Sunfounder. It has fewer components than the ultimate one, a lower price as well.
  • The kit has 40 professional project tutorials available online.
  • Has a separate jumper wire kit with different size wires for prototyping.
  • Lots of passive components like resistors, capacitors, etc. Perfect for making simple electronics projects.
  • Sensors: 2 (PIR and LDR)
  • Display: 1 x 7 Seg. and 1 x LCD
  • Input devices: Buttons, Switches
  • Motor: 1 ( Servo)
  • Breadboard: Yes
  • Box: Yes
  • Lots of passive components and fewer sensors.
UCTRONICS Raspberry Pi Pico Starter Kit
UCTRONICS for Raspberry Pi Pico Starter Kit, Pico…
  • Why is the kit a must-have? This kit is designed to be used alongside the free Official book, It includes every component you need to get started with the book and you won’t have to run out to the store for anything extra.
  • This is the cheapest kit available online.
  • Pre-soldered Pico board
  • Sensors: 1 x PIR
  • Display: 1 x LCD
  • Input devices: Push-button
  • Motor: 0
  • Breadboard: Yes
  • Box: Yes
  • The display provided in the kit is different than the one shown so you will need to refer to the correct wiring.
  • Very few components.
Conclusion – Best R-Pi Pico Kits
Many Raspberry Pi Pico Starter Kits are available in the market. But don’t get confused. We hope that through this article you might have got the appropriate kit among the various R-Pi pico kits available in the market. If by any means you are still confused we suggest you the SunFounder Raspberry Pi Pico Ultimate Starter Kit. Do let us know in the comments if you feel we have missed a better one.
Kanishk Godiyal
