10 Best USB-C to AUX Cables and Adapters in 2026
Last updated on January 6th, 2026 at 11:34 am
Wireless earphones are dominating the market. Many are shifting to wireless earphones due to their hassle-free use. But there’s no denying that sometimes old is gold. Wireless earphones do not give as good noise cancellation as wired ones can. Of course, there are amazing wireless noise-cancellation earphones, but they are often available at high prices. That’s not convenient for everyone.
It has been observed that several mobile manufacturers are eliminating the earphone jack as people are switching to wireless. But old schoolers like us would like to use wired earphones. The ideal solution is to use an adapter. We also like to connect our mobile to cars, Bluetooth speakers, headphones, etc. To do that we will require a USB-C to AUX cable. So we have compiled a list of the top USB-C to AUX cables and adapters in the market.
Our top picks on USB-C to AUX cables & adapter
JSAUX USB C to 3.5mm headphone and charger adapter
Size: 11 in x 0.15 in x 0.15 in
Color: Gray, Black, Red
Our phones have only one USB-C port, so if you use it to connect an AUX adapter you won’t be able to charge your phone. This problem is resolved by this 2-in-1 USB-C to AUX adapter by JSAUX. It has 2 ports; one is AUX and another is USB-C. So now you can connect your earphones and charge your phone simultaneously.
The adapter supports charging up to 30 W. It has a PD MAX charging chip for fast charging. You can use all the usual earphone controls, such as receive calls, control volume, etc while using the adapter. The DAC chip supports data transmission of 48 kHz/16 Bit, so you can listen to high-quality audio.
The adapter is built with an aluminum case making it strong. The cable is nylon braided and can handle 15,000+ bend cycles. For a 2-in-1 adapter, this one is available at a great price.
CableCreation USB C to 3.5mm headphone and charger adapter
Size: 3.9 in x 2.48 in x 0.63 in
Color: Space Gray
Warranty: 2 years
This USB-C to AUX adapter from CableCreation has a similar function to that of the JSAUX USB-C to 3.5mm Headphone and Charger Adapter. But this one has a more compact and ergonomic design. It is shaped like a small rod with no cable that fits the width of your mobile. You can connect a 3.5 mm AUX to one end and a USB-C to the other.
It supports 60 W PD charging. Please note that data transfer is not supported by this adapter. But this one has proved to give a Hi-Res sound quality because of its DAC chip. The aluminum case, along with the internal protection mechanism, gives proper heat dissipation.
The gold-plated USB-C connector gives better performance than its competitors. The manufacturers provide 24/7 customer service to help you with any difficulties with the product.
Check also: Best USB-C to HDMI Adapters (Our Top 7 Picks)
UGREEN USB C to 3.5mm audio headphone jack adapter
Size: 5.63 in x 3.35 in x 0.55 in
Color: Gray, Black
This USB-C to AUX adapter from UGREEN has a similar ergonomic design as of CableCreation USB C to 3.5mm Headphone and Charger Adapter minus the USB-C port. This has a single AUX port. It’s almost half in size as the CableCreation one. It’s an excellent right-angle dongle to connect your earphones.
Due to its shape and compact design, the breaking of earphone cables is minimized. It has a Hi-Res DAC chip to provide Hi-Fi sound quality along with noise reduction and anti-interference properties. It’s compatible with up to 96kHz/24-bit of sound quality.
It supports a mic and in-line controls on the earphones. The body is made from premium anti-rust aluminum which resists corrosion and oxidation and also prevents scratches. This is a very compact solution to your earphone connection problem.
UGREEN USB C to 3.5mm headphone and charger adapter
Size: 1.18 in x 1.77 in x 0.39 in
Color: Gray
UGREEN has many designs available for USB-C to AUX adapters. This is one of them. This one has an adapter case having two ports beside one another. One for AUX and one for USB-C. So you can enjoy 60 W PD fast charging with Hi-Res music of up to 96 kHz/ 24 bit.
The case is made of a high-quality aluminum alloy shell, making it wear-resistant. The cable is a sturdy TPE cord to prevent breakage. It has a smart chip to convert digital to analog signals. It is just like most other USB-C to AUX adapters but with a more bulky design.
JSAUX USB Type C to 3.5mm headphone stereo cord
Size: 3.3 ft, 6.6 ft
Color: Red, Black, Blue, Gray
JSAUX provides the ultimate solution for your audio transfer needs. It provides the most stable sound quality you will ever get. The upgraded DAC smart chip ensures no signal is lost in the transmission and no noise is added to the signal. The cable is 10 times more durable than its competitors.
The nylon braided cable can be twisted and turned as you wish, but it will be hard to break. The connectors are put together by laser-wielded technology which makes it the most robust connection. A reinforced strain relief component is applied to the connectors to avoid breakage from bending. It could withstand 20,000+ bend cycles. The supported sound quality is up to 16-bit/48 kHz.
Check also: 6 Best USB to Micro USB Cables (USB-A & USB-C)
Apple USB-C to 3.5 mm headphone jack adapter
Size: 2.65 in x 0.66 in x 3.43 in
Color: White
Apple was the first company that stop providing an AUX port on their devices. So it was also the first company to manufacture a USB-C to AUX adapter. This is the most premium USB-C to AUX adapter available. It is safe for iPhones as it is from Apple itself. But you can use it on any device having a USB-C port.
It comes in the signature white color. It is very compact. The cable has a high-grade Nylon coating to make it durable. The connecter is made of high-quality material to avoid breakage. Other companies have taken inspiration from this product to create their own USB-C to AUX adapters.
Anker USB C to 3.5mm audio adapter
Size: 4.45 in x 0.43 in x 0.24 in
Color: Dark Gray
Anker cables and adapters are famous in the market due to their reliability and high performance. This USB-C to AUX adapter by Anker is no exception. It has a USB-C connector on one end and an AUX adapter on the other. With this adapter, you can retain the complete functionality of your earphones. You can play/pause, and control the volume and microphone even when plugged into the adapter.
The USB-C end has a DAC chip installed which is responsible for Hi-Fi sound. The chip converts a digital signal to an analog at a transmission rate of 96 kHz/ 24 bit. The adapter cable is made of high-quality braided nylon material.
You can tug it, twist it, bend it, but it won’t easily break. It can go through 15,000 bend cycles, making it quite durable. The connector has passed the plugging and unplugging test 10,000 times. This is re
LecLooc USB C to AUX cable
Color: Gray
A USB-C to AUX cable is ideal for directly transferring audio data from your device to an audio output. This particular cable by LecLooc is ideal for the purpose. This cable is aesthetically pleasing. But beauty is not the only good thing about this one.
It has a braided texture which provides the highest possible strength to the cable. The connectors are plated with gold so that they prevent corrosion and give high performance even with extended use. The enameled copper core and high-fidelity shielding design make this cable durable, reliable, and strong.
This cable ensures that there is no transmission loss and sound quality is transferred as intact as possible. It can transfer Hi-Res audio of up to 24bit/192KHz. The signal-to-noise ratio can be as high as 100 dB.
UGREEN USB-C to audio cord
Color: Gray
With UGREEN USB-C to AUX cable, you can expect Hi-Fi stereo output. The DAC chip makes sure that only high-quality audio transmission takes place. This cable can give an audio output of 24bit/96kHz. The connectors have an aluminum alloy case which is anti-rust, so your cord will be free of corrosion.
It has a durable braided cable that will not only provide a casing to the inner enamel copper wires but also high strength. The reinforced strain relief connection passed the bend test 15,000+ times. The cable always remains tangle-free and is thus easy to use. Carry it around anyhow and you still will get the best audio quality.
JXMOX USB C to 3.5mm headphone and charger adapter
Size: 5.16 in x 3.03 in x 0.28 in
Color: Gray
This USB-C to AUX adapter from JXMOX has two cables coming out from the USB-C end of the adapter. One cable has a USB-C port at its end, and the other has an AUX port. Both cables have a double braided texture to withstand the wear of everyday use. The connector and the lining of the ports are plated with gold to give high performance.
It puts you out of your worry about not being able to charge your phone while listening to music. It supports fast charging from the USB-C port and Hi-Fi sound from the AUX port. You can operate all the in-line controls when connected to the adapter. The built-in DAC smart chip supports up to 96 kHz/ 24 bit.
Conclusion – Best USB-C to AUX Cables and Adapters
USB-C to AUX cables and adapters are available in many designs and forms. Some come with an additional USB-C port for charging. If you feel the need for both ports, then opt for a dual port adapter. Before buying a cable or an adapter, check the audio transmission rate. Some provide better transmission than others. Also, check whether you can operate in-line controls on your earphones when connected to the adapter.
Kanishk Godiyal
