7 Best USB-C to DVI Cables and Adapters in 2026(Top Quality)
Last updated on January 6th, 2026 at 11:34 am
Old screens used to have DVI ports which were later replaced with other data transfer ports. But we still use devices with a DVI output. Nowadays, no direct connection is available between the host and a DVI-supported screen. So we need to use a cable or an adapter.
An adapter or cable with a USB-C male end will be ideal, as most of the recent devices have a USB-C port. With adapters and cables, you can connect your device to a high-resolution display. To make your choice easier, we have picked the top USB-C to DVI cables and adapters in the market.
Our top picks on USB-C to DVI cables & adapters
CableCreation USB C to DVI Adapter
Size: 7.24 in x 4.61 in x 0.55 in
Color: Black
Warranty: 2 years
CableCreation is one of the few popular brands that people trust. Its products never disappoint. This USB-C to DVI adapter from CableCreation can transfer video data of resolution up to 1080P at 60 Hz. It is made of high-quality materials. It comes in two types of shells, viz. ABS and Aluminum.
ABS shell is lightweight and less bulky, whereas aluminum shell is good for heat dissipation. The connecter is gold-plated, so we can expect high performance. It gives amazing signal transmission. It is resistant to corrosion, so the chances of breakage are minimal.
This is a plug-and-play type of adapter, so you will not need to perform any additional installations. The manufacturer provides free lifetime technical support, so you can contact them with any queries or difficulties with the product.
UPGROW USB C to DVI Cable
Size: 4 ft, 6 ft
Color: Black
If you need a male DVI connecter instead of a female port then this USB-C to DVI cable is perfect for you. It supports 4K resolution at 30 Hz. The connectors are designed in a way to reduces interface damage and allows faster and more stable transmission.
The gold plating contributes to better performance and makes it resistant to corrosion and damage from everyday use. The cable itself is coated with PVC polymer, which makes it durable. You get a choice between 2 length options, so you can choose one that is perfect for your requirements. The user-friendly design will make your work simple.
Benfei USB 3.1 (USB-C) to DVI-D Adapter
Size: 0.39 in x 0.39 in x 0.39 in
Color: Gray
BENFEI adapters are very durable. They have an aluminum shell that allows for proper heat dissipation and provides strength. The gold-plated connectors are resistant to corrosion and hence are stronger than its competitors. It has an advanced IC chip that converts signals at great speeds.
It supports an output of 1080P at 60 Hz.  It is a plug-and-play type of adapter, so there is no need to install any drivers. It is portable and hence easy to carry around. If you ever encounter any problems with the adapter, you can contact the very helpful customer service.
Benfei USB Type-C to DVI Cable
Size: 3 ft, 6 ft
Color: Black
This USB-C to DVI cable is very similar to the one from UPGROW. It can transfer video data at a resolution of 1080p at 60 Hz. so that you can enjoy high-definition and clear pictures. By using two of these cables together, you can use your monitors in mirror mode and extend mode simultaneously.
The upgraded chip solution used in the cable makes it smart enough to make transfers as required. The cable is 32 AWG grade, so you can trust it to be durable. It is going to be your reliable video transmission partner. The gold-plated connectors are an added plus, as they will not only enhance performance but also prevent the connectors from corroding. While the reinforced casing will give better heat insulation.
Cable Matters USB C to DVI Adapter
Size: 4.13 in x 2.76 in x 0.71 in
Color: Black
This is another USB-C to DVI adapter from a reputed brand. It supports a video resolution of 1920×1080 at 60 Hz. It holds its place when connected, avoiding slippage and hence providing a stable connection. It weighs less than 1 oz, so you can carry it around in your pocket.
It has gold-plated connectors to provide enhanced performance. All in all, it is very carefully engineered to be versatile, powerful, and easy to use. It is a little more expensive than its competitors, but the product is worth a few extra bucks.
Cable Matters USB C to DVI cable
Size: 3 ft, 6 ft, 10 ft
Color: Black
When it comes to Cable Matters cables, people trust them with their eyes closed. The brand has built its reputation by providing high-quality, budget-friendly products. This USB-C to DVI cable is no exception. The product is designed in a way to give the highest user experience. The strong thumb screws keep your DVI connector in place when plugged in.
The DVI connectors have an easy grip surface to allow efficient plugging and unplugging. There are 3 length options available, so you can choose one that’s most convenient. The gold-plated connectors provide strength, so there’s no breakage while plugging/unplugging. This cable can transfer video of resolution up to 1920×1080 at 60Hz.
CableCreation 3 in-1 USB Type C to HDMI VGA DVI Adapter
Size: 9.25 in x 6.02 in x 0.67 in
Color: Black, White
Warranty: 24 months
If you are looking for a universal adapter for all your video transmission ports, then this one is perfect for you. It has a USB-C connector and 3 types of ports. An HDMI port, a VGA port, and a DVI port. You can use only one port at a time. With this adapter in your bag, you will have to look nowhere else for video transmission options.
It will improve your work efficiency. The HDMI port supports a resolution of 4k at 30 Hz with a bandwidth of 9 Gbps. The VGA port supports 1920×1200 at 60 Hz, whereas the DVI port supports a resolution of 1080P at 60 Hz. You get lifetime technical support on buying this adapter.
Conclusion – USB-C to DVI Cables and Adapters
We hope that through this article, you might have found the perfect USB-C to DVI cable/Adapter. We recommend getting the one that will fit your budget and also give the best performance possible. Make sure to check your system requirements and decide whether a cable or an adapter will suit your needs.
Kanishk Godiyal
