10 Best USB C to Lightning Cables You Can Buy in 2026
Last updated on January 6th, 2026 at 11:33 am
USB C is becoming the new standard connection type. But we still have devices that require USB A or Lightning connections. A USB C to Lightning Cable is the perfect solution to connect such devices. This cable can be used for charging devices with a Lightning port.
We sometimes need to transfer data from an iPhone to another device but might not have a compatible device to do it. That’s where USB C to Lightning Cables come into the picture. These cables can be used to share data between devices.
Let’s take a look at some of the best USB C to Lightning Cables.
Our top picks on USB-C to DVI cables & adapters
Anker USB-C to Lightning Cable
Length: 3 ft, 6 ft
Colors: Black, Blue, Green, White, yellow, Light Purple, Pink, Purple
Most iPhone users love USB C to Lightning cables from Anker. It is a highly reputed brand in the market. The cable comes with an MFi certification, meaning you can safely use it for Apple products. There are 2 length options available – 3 and 6 ft, so you can get one that’s most comfortable.
You get to choose from a wide variety of vibrant colors. The cable has a silicon finish that glides smoothly between your fingers. It is the softest USB C to Lightning cable available on the market.
Despite being soft, the cable is quite sturdy. It has passed the bend test 25,000 times. It remains tangle free irrespective of how you store it. It is perfect for fast charging and rough use.
UGREEN 90-Degree USB-C to Lightning Cable
Length: 3 ft, 6 ft
Colors: Grey
Warranty: 24 months
UGREEN manufactures one of its kind MFi certified USB-C to Lightning Cable. It has a 90-degree connector at the Lightning end of the cable. This cable is perfect if you want to save space or give your setup a sleek look. The 90-degree connector is much more durable than the regularly shaped ones, as the chances of breakage due to bending is minimal.
This makes the cable ideal for playing video games and watching videos while charging your device or transferring data. Besides giving a charging speed of 0% to 60% in 30 minutes, this cable also allows a transfer speed of up to 40 Mbps.
This cable has the new C94 connector that has passed the 10,000+ plug/unplug tests. It has a braided texture making it durable and resistant to breakage on bending. The bend test for this cable gave the thumbs up 15,000+ times. You can buy this one with your eyes closed.
Apple USB-C to Lightning Cable
Length: 1m, 2m
Colors: White
Warranty: 1 year
Apple was the first company to manufacture a USB-C to Lightning cable. This is the standard that all other manufacturers follow to create USB-C to Lightning Cable. Many users prefer to use the original Apple products with their Apple devices.
This cable comes in 2 different sizes, but there are no color options available. The smooth finish of the cable always keeps it tangle-free. The cable is ideal for charging and syncing your MAC devices. The cable is compatible with Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB‑C Power Adapter. This cable provides fast charging for selected models of iPhone and iPad.
inCharge 6 USB C to Lightning Cable
Length: 5 ft/ 1.5m
Colors: Mercury Grey Max
InCharge manufactures a universal six-in-one cable, which has a USB-C to Lightning connection. This cable has 4 different types of input/output, viz. USB, USB C, Micro USB, and Lightning. The connectors are made of a high-quality zinc-aluminum alloy that makes the cable extremely strong. It is very lightweight, weighing only 2.26 ounces.
The cable itself is made from 90 braided copper wires, which is great for fast charging as well as data transfers. Unlike most cables, this cable has a flat design making it easy to store. The cable is capable of charging a device and syncing data between two other devices simultaneously.
There is no restriction on the number of ports you can use simultaneously but make sure you are not drawing more power than the adapter can supply.
Satechi USB-C to Lightning Charging Cable
Length: 10 in/25 cm
Colors: Gray
Warranty: 1 year
This USB-C to Lightning cable from Satechi is perfect for use with a power bank due to its short length. The 10-inch cable remains tangled-free always. You can easily carry it with you on the go. This cable can also be used for Apple products as it has MFi certification.
This cable has a high charging speed. It can charge your device up to 50% in less than 30 minutes. The cable itself has a braided texture which gives an excellent grip and not to mention strength. The space gray aluminum accents are made for durable use.
The reinforced connectors ensure the cable doesn’t break by bending. It may look small, but it is as powerful as the strongest USB-C to Lightning cables.
Spigen DuraSync USB C to Lightning Cable
Length: 3.3 ft/ 1m
Colors: White, Black
If you want to buy two USB-C to Lightning cables together, then this is your ideal choice. You will definitely save a few bucks if you opt for a pack of two rather than buying individual cables from Spigen. This cable is of decent length and quality. The manufacturer guarantees lifetime durability. In a bend test, the cable passed 30,000 bends which are higher than most cables out there.
It has an ergonomic design well suited for persistent plugging and unplugging. That makes this product of great value for its price. The product is also MFi certified, making it perfectly compatible with Apple devices. In our opinion, this is a great deal.
Deloni USB C to Lightning cable
Length: 10 ft, 6 ft, 3 ft
Colors: White, Black, Blue, Green, Purple, Red
Warranty: 3 years
This USB C to Lighting cable from Deloni comes in a pack of 1 and 2. The cables come with a charging adapter included. You will find a variety of length and color options with this product. The smooth matte white finish looks like an original Apple USB C to Lightning cable.
The length of the cable makes it suitable for using your device comfortably while charging (though that is not recommended). This product is made for fast-charging MAC devices. It is a travel-friendly product. Being an MFi-certified product (Made For iPhone/iPad/iPod), it is trustworthy to use with your Apple devices.
NATIVE UNION USB-C to lightning cable
Length: 4 ft
Colors: Cosmos, Indigo, Rose, Sage, Zebra
This is the most aesthetically pleasing USB-C to Lightning cable we have encountered. It has an original leather belt to keep the 4 ft-long cable organized. This board leather belt is the key aesthetic element. This cable comes in several colors and textures, one more pleasing than the other.
Apart from the aesthetics, the cable has an o-flex strain relief design that can handle 2x more strain than most cables. It has a bend lifespan of 10,000+. The reinforced cable construction is stronger than most cables, making it ultra-strong. It offers unparalleled strength and durability.
With this cable, your device can charge up to 50% in under 30 minutes. This cable is MFi certified, and each cable has its unique serial number, so you know that you got the real deal.
Amazon Basics USB-C to lightning cable
Length: 3 ft, 6 ft
Colors: Drak Grey, Rose Gold, Silver
Amazon has several high-quality products under its ‘Basics’ range. This USB-C to Lightning cable is one of them. It comes in 2 sizes and 3 colors, so you have got a lot of options. You can also opt to buy a charging adapter along with the cable. The Nylon braided wire gives the cable strong protection from breakage by bending.
It is designed to withstand 4,000 bend cycles. The connector ends are made from aluminum which makes them strong and lightweight. This product is not only MFi certified but also used Apple’s original smart chip. This will give the closest performance to the original Apple cable.
The charging speed is 0% to 100% in 2 hours. Alongside this, the cable can transfer data at a high speed of 480 Mbps.
Sundix USB-C to lightning cable
Length: 3 ft, 6 ft, 10 ft
Colors: Blue, Black Blue
Warranty: 1 year
If you want to buy USB-C to Lightning cables for your entire family, then this pack of 3 from Sundix will be the best buy. You almost get 3 cables at the price of one. And the best part is each cord comes with a different length of 3 ft, 6 ft, and 10 ft. So whenever you feel the need for a longer or shorter cable, you can just grab one from the pack.
This product is also MFi certified, so you need not worry about its safety standards. You can charge your devices at a super speed of 50% in 30 minutes and transfer data at a rate of 480 Mbps. The USB C has a reversible connector, so you don’t have to check for direction every time.
There is a built-in gold-plated layer that enhances the performance of the cable. The braided exterior of the cable makes it sturdy for everyday use.
Conclusion – Best USB C to Lightning Cables
All cables on this list are MFi certified, so you can place your trust in them with your eyes closed. Each cable is different in its way. Each of them delivers to your comfort and preference. Now you need to decide which product suits and fulfills your needs.
We would suggest going for a proper length that won’t be too short or too long for your needs. And select one with fast charging and data transfer capabilities for smoother performance.
Kanishk Godiyal
