7 Best USB C to VGA Adapters of 2026(Buying Guide)
Last updated on January 6th, 2026 at 11:32 am
VGA ports are used to transfer video and pictorial data across devices. But most recent devices do not have a VGA port. Instead USB C port is taking the dominant place. So to play data on a screen, one can use a USB-C to VGA adapter. These adapters can be plugged directly into your device’s USB-C port, and the VGA cable can be plugged into the other end of the adapter.
Using an adapter will make the connection hassle-free. You can get high-quality video output depending on the adapter you are using. These adapters are compatible with any device with a USB-C port, whether a laptop, tablet or mobile phone. Let’s look at some of the best USB C to VGA adapters in the market.
Note: VGA ports can transfer only video content and no audio content. All of these USB-C to VGA adapters can transfer video content to VGA monitors and screens. With this, you can use your old monitor as an extension to your new device.
Our top picks on USB-C to DisplayPort cables & adapters
Benfei Thunderbolt 3 USB-C to VGA Adapter
Size: 0.39 in x 0.39 in x 0.39 in
Color: Gray
This USB-C to VGA adapter by Benfei is unidirectional, i.e. you can transfer data from the USB-C port to the VGA output but not the other way around. This adapter is installed with a smart chip that maintains a clear and stable signal. This adapter allows you to mirror the source screen or use a second screen as an extension of the first.
It supports resolutions up to 1920 x 1080p at 60 Hz. The adapter is very compact and small in size, making it easy to carry. The connector is gold-plated, making it resistant to corrosion and improving its performance. This is the best USB-C to VGA adapter at the lowest price.
INTPW multiport adapter
Size: 3.54 in x 2.13 in x 0.55 in
Color: Gray, Silver
This is not just a USB-C to VGA adapter. It has 3 additional ports: a USB-C, one HDMI, and one USB 3.0 port. This adapter is perfect if you want to connect a VGA and an HDMI output simultaneously to a device. This proves useful if you have two output screens with different connection ports. But your device should support simultaneous casting on two screens.
There are 2 colors available with a slight price change. The USB-C port can only be used for charging. The USB 3.0 port can transfer data at a speed of 5 Gbps. The HDMI port supports 4K resolution at 30 Hz, whereas the VGA port supports 1080p at 60 Hz.
The adapter allows mirror mode as well as extend mode. The adapter has an aircraft-grade aluminum shell, making heat dissipation quick. The manufacturer offers a 6-month refund along with an 18-month warranty and lifetime customer service.
Amazon Basics Type-C to VGA Adapter
Size: 1.65 in x 1.38 in x 0.63 in
Color: Gray
Warranty: 1 year
Amazon sells this USB-C to VGA adapter under its ‘Basics’ range. It supports the transfer of video having HD resolution up to 1920×1200 or 1080p. The adapter’s body is lightweight and robust as it is made of aluminum. The design is slim and well-suited to carry around.
The cable is coated with silicon which has a smooth finish. The connector is also made from aluminum, thus minimizing the chances of breakage. This adapter doesn’t need the installation of any external drivers for usage. You can simply plug it in and use it. This is a cheap adapter with good quality.
Bincolo USB C (Thunderbolt 3) to VGA converter
Size: 6.88 in x 1.45 in x 0.47 in, Cable: 4.3 in
Color: White
This is just another USB-C to VGA adapter. It comes in white. It is quite lightweight, weighing only 1.22 oz. This makes it easy to carry around. This is also a plug-and-play type of adapter, so no installation of drivers is required. This adapter can transfer video data of 1080P at 60Hz.
This adapter has a reinforced TPE cable coating which reduces any signal interference with wireless devices. The adapter itself is made of premium aluminum. Because of this heat dissipation capacity of this adapter is high.
SGEYR USB C to HDMI VGA adapter
Color: Gray
Warranty: 24 months
This 2-in-1 port by SGEYR is only for video data transfer. The USB-C cable can be directly plugged into any compatible device, while VGA and HDMI cables can be inserted into the respective ports. This adapter allows the transfer of video data to different screens with different connectors simultaneously.
Each port allows the use of an output screen in 2 modes, viz., mirror and extend. The HDMI port supports a maximum resolution of 3840×2160 UHD 4K at 30Hz. The VGA port supports a maximum resolution of 1920×1200 FHD at 60Hz. The adapter has over-voltage, over-charging, and over-heat protections as it is made from aluminum alloy; apart from that, the cable promises a stable signal transmission.
CableCreation USB type C to VGA converter
Size: 0.24 in x 9.37 in x 6.3 in, Cable: 4.45 in
Color: Black
Warranty: 24 months
CableCreation has this extremely elegant-looking USB-C to VGA adapter. It comes in black with a shiny finish. This adapter comes in two types of shells, viz. ABS and Plastic. The ABS shell is also available in white color. The golden brand name and gold-plated connector make it look more classic.
The gold-plated connector improves the performance of the adapter. This adapter supports a resolution of 1080P at 60 Hz. It is a plug-and-play type of adapter, so there is no need for any installations. CableCreation is a reputed brand in the market, making this specific adapter a great pick.
BENFEI USB Type-C to HDMI VGA display port adapter
Size: 1.97 in x 1.57 in x 0.39 in
Color: Blue
This USB-C to VGA adapter by BENFEI comes in two types:
  • One in which there’s a VGA port, an HDMI port, and a DisplayPort
  • Another in which the DisplayPort is replaced by a USB 3.0 port.
The USB 3.0 version is cheaper than the DisplayPort version. This is the ultimate adapter if you are looking to connect your device to multiple display screens. When connected simultaneously, all three screens can reach the highest resolution of 1920×1200 at 60 Hz.
When HDMI and VGA are used simultaneously, the highest resolution reached is 1920×1200 at 60 Hz. When DisplayPort and VGA are used simultaneously, the highest resolution reached is 1920×1200 at 60 Hz.
And when HDMI and DisplayPort are used simultaneously, the highest resolution reached is 3840×2160 at 30 Hz. This adapter gives incredible performance, given that three display outputs can be connected simultaneously.
Conclusion – 7 best USB C to VGA adapters
While choosing a USB-C to VGA adapter, keep in mind to look at your requirements. If you don’t need the additional ports, then don’t go for a multiport adapter, as a single port will satisfy your needs. Also, keep in mind your device’s charging requirements. If your device has a single USB-C port, then you might need a multiport adapter for charging your device.
Kanishk Godiyal
