Last updated on April 5th, 2024 at 11:06 am
Micro USB cables are outdated. But we still use devices such as tablets, gaming consoles, cameras, etc that require a Micro USB cable. For all such devices, we need USB to Micro USB cables. The USB-C is the most common standard used in the market, taking over USB-A.
But still, many charging adapters have a USB-A port. So it is necessary to have USB-A and USB-C to Micro USB cables. We understand your need, so we curated a list containing the top USB-A to Micro USB cables and USB-C to Micro USB cables.
“Our recommendation for USB to Micro-USB cable“
6 Best USB to Micro USB Cables
AmazonBasics USB-A to Micro USB Cable
Size: 3 ft, 6 ft, 10 ft
Color: Black
This is a USB-A to Micro USB Cable from AmazonBasics that comes only in Black color. But, it is available in 3 sizes – 3 ft, 6 ft, and 10 ft. It is also available in packs of 1,2, 3, and 5. You can also opt to get a wall charger along with this cable.
Features:
- The cable is enclosed in a silicon coating to protect it from damage.
- The connectors on both ends are gold-plated enhancing their performance and making them resistant to corrosion.
- This cable can transmit data at a speed of 480 Mbps.
CableCreation USB to Micro USB Fast Charger Cable
Size: 0.5 ft, 4 ft
Color: Black, Grey
Warranty: 24 months
If you are looking for a short USB-A to Micro USB Cable, this is the one for you. It is merely 0.5 ft long. You also get a 4 ft-long version of this cable. It comes in two colors – Black and Grey. The Grey one is more of a zebra pattern.
Due to its small size, it doesn’t cause any clutter in your working space. This is ideal for connecting a power bank to your device. It’s perfect to connect a TV stick to your TV.
Features:
- This cable can be connected to a 5V/1A output.
- Even though the cable is short, it is braided which makes it stronger than the others. It can withstand 10,000+ bend cycles.
- The wire is perfect for fast and safe charging as it is of 24AWG grade.
- The conductor wire is also shielded with multiple layers. This is good for safely charging your device and minimal harm to the cable.
Anker Powerline 3-in-1 Cable
Color: Black, White
Warranty: Lifetime
This is a 3-in-1 Cable from Anker. It has a USB-A connector on one end and 3 different connectors on the other end. You can select between Micro USB, Lightning, and USB-C connector for the other end. You can use only one of the three connectors at any time. The Lightning connector is MFi certified which proves it is safe for Apple devices.
Features:
- The conducting wires have bulletproof fiber reinforcement and the outer casing is a soft TPE finish for lifelong durability.
- It can handle over 12,000 bend cycles.
- The connectors are rust-proof so that they don’t break after long-term use.
- Along with fast charging, this cable can transfer data at a speed of 10 Gbps.
- It has a lifetime guarantee.
CableCreation Short Micro USB to USB C Cable
Size: 0.65 ft, 3.3 ft, 4 ft, 6.6 ft
Color: Black, Grey
Warranty: 24 months
This cable has a similar structure to the CableCreation USB-A to Micro USB Fast Charger Cable. The gold-plated connectors, aluminum shell, braided cables, tinned copper conductors and foil, shielding layers, color combinations, size, everything is the same. The only difference is instead of a USB-A connector, we have a USB-C connector on this one.
Features:
- It can also undergo 10,000+ bend cycles, has high strength and durability, and is made of high-quality materials.
- This cable can transfer data from the USB-C host to the Micro USB port.
- Charging is only supported from USB-C to Micro USB.
Cable Matters Braided USB C to Micro USB Cable
Size: 1 ft, 3 ft, 6 ft
Color: Black
Warranty: Lifetime
Cable Matters is a reputed brand in the market. Their cables are loved by numerous users. This cable from them is useful for charging Micro USB devices from a USB-C charger or transferring data from a USB-C device to a Micro USB device at a speed of 480 Mbps. It comes only in Black color and 3 size options.
Features:
- It is a strong cable and has a distinctive look due to its braided cable.
- It is lightweight and easy to carry around.
- The connectors are molded to relieve strain so they can be plugged unplugged without breaking.
- The cable itself is fully shielded and provides superior transmission performance.
- The lifetime warranty gives the buyer a sense of security and safety while buying this cable.
Fasgear USB C to Micro USB Cable
Color: Black, Grey
This is a high-performance USB-C to Micro USB cable. It is really good for the price. It comes in 3 sizes and 2 colors. The 21 AWG power cord can handle a maximum current of 3A, while the 28 AWG data cable that can transfer data at a speed of 480 Mbps.
Features:
- The connectors have a hard metal shell preventing them from breaking.
- The cable has a braided Nylon cover to handle bending from everyday use.
- It has been tested to pass over 10,000 bend cycles.
- The manufacturer offers customer service along with an 18-month warranty.
Conclusion – Best USB to Micro USB Cables
The continuous evolution of devices has led to the requirement for different types of cables. There’s no need to get confused by looking at two different types of cables. You simply have to identify your host device’s port. If it has a USB-A port, you will need a USB-A to Micro USB cable, and if it has a USB-C port, you will need a USB-C to Micro USB cable.
