Lightning Connector and Port Pinout With FAQs
Last updated on November 4th, 2025 at 12:11 pm
The lightning cable comes with an 8-pin symmetrical connector. Thus, it can be inserted into a Lightning port from either side regardless of positive and negative orientation. The pinout diagram of a lightning connector is given below.
Lightning Cable and Port Pinout
Lightning cable/connector and port pinout
The pin description is as follows.
Pin NumberPin NameDescription
Pin 1GNDGround
Pin 2L0pLane 0 positive
Pin 3L0nLane 0 negative
Pin 4ID0Identification/control 0
Pin 5PWRPower
Pin 6L1nLane 1 negative
Pin 7L1pLane 1 positive
Pin 8ID1Identification/Control 0
Pinout of Lightning Cable
Note: The lightning port is the device to which the connector end of Lightning cable is inserted. Hence pinout is same for both devices. But their orientation should be carefully observed according to the pinout diagram.
Let’s look at the pinout of both port and connector separately now.
Lightning port pinout
Given below is the pin diagram of the Lightning port present on Apple devices.
Lightning Port Pinout
Lightning cable pinout
Given below is the pin diagram of the connector of a Lightning cable.
Lightning Cable/Connector Pinout
Lightning connector pinout
What are the pins on a Lightning cable?
There are a total of 8 pins on the Lightning cable. One power and one Ground pin, Lane 0, Lane 1 positive and Lane 0, Lane 1 negative pins, and Identification/Control 0 and 1 pins. (Read More)
How many pins are in a Lightning cable?
A Lightning cable has 8 pins. Due to its reversible nature, a Lightning cable can be inserted into a Lightning port in either direction.
Which pins are power on Lightning Cable?
Pin 5 in a lightning cable is used to provide power, whereas pin 1 is the ground pin.
Why does pin 4 or 5 turn black in a Lightning Cable?
Depending on the direction you are holding the cable, pin 4 or 5 of the cable is a power supply pin. When you connect the cable to the lightning port, sometimes there lies a tiny gap between the cable and the port. As there is no direct contact between them, the electric current flows from the cable to the port in the form of a spark. This spark damages the copper layer in the cable, thereby turning it black.
What is 8 pin Lightning Connector?
An 8-pin lightning connector is used to connect Apple devices like iPhones, iPads, and iPods to computers, laptops, USB battery chargers, or other peripherals via a Lightning cable.
Note: While Lightning ports dominate Apple devices, other connectors like HDMI and DVI remain the backbone of display transmission for computers and monitors.
Learn how DVI and HDMI differ in their structure and performance.
Blessy C Simon
I'm an AI researcher who enjoys writing. Whether it's crafting compelling blog posts, or optimizing web content for search engines, I have a knack for tailoring my writing style to suit various niches and audiences.
1 thought on “Lightning Connector and Port Pinout With FAQs”
  1. If the lightning port had pins on both sides, would have been faster and also making data faster. What is your point of view.
    Reply
