This is a Smart Notice Board built using an ESP32 microcontroller board. It allows users to enter messages into a web interface, which is then displayed on an LCD screen. This combination of hardware and web connectivity enables remote messages to be updated on the LCD.
This project involves creating a digital notice board using an ESP32 microcontroller, which connects to the internet via Wi-Fi. Users can access a dedicated web page to enter the messages they want to display. The ESP32 receives these messages and displays them on a scrolling LCD screen. This idea provides an effective approach to displaying messages digitally, reducing the need for traditional paper notices.
Components Required
- ESP32 Microcontroller Board
- 16×2 LCD With I2C Module
Circuit Diagram
This is a circuit diagram of ‘Smart Noticeboard‘ using ESP32.
| LCD16x2 I2C Pin | ESP32 Pin |
| VCC | 3V3 Pin |
| GND | GND of ESP32 |
| SDA | GPIO21 |
| SCL | GPIO22 |
Physical Connections
This is a physical connection diagram. We used a breadboard to connect the LCD 16×2 I2C with ESP32.
Program for Smart noticeboard
#include <WiFi.h>
#include <Wire.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);
AsyncWebServer server(80);
const char* ssid = "SSID"; //wifi ssid
const char* password = "PASSWORD"; //wifi password
const char* PARAM_INPUT_1 = "input1";
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html><head>
<title>Smart Notice Board</title>
<meta name="viewport" content="width=device-width, initial-scale=5">
<p> <font size="9" face="sans-serif"> <marquee> Smart Notice Board </marquee> </font> </p>
</head><body><center>
<form action="/get">
Enter Text to Display: <input type="text" name="input1">
<input type="submit" value="Send">
</form><br>
</center></body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
request->send(404, "text/plain", "Not found");
Serial.begin(115200);
lcd.init();
lcd.clear();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Smart Notice Board");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("WiFi Failed!");
return;
Serial.println();
Serial.print("IP Address: ");
Serial.println(WiFi.localIP());
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html);
server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
String message;
String inputParam;
if (request->hasParam(PARAM_INPUT_1)) {
message = request->getParam(PARAM_INPUT_1)->value();
inputParam = PARAM_INPUT_1;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(message);
else {
message = "No message sent";
inputParam = "none";
Serial.println(message);
request->send(200, "text/html", index_html);
server.onNotFound(notFound);
server.begin();
for (int positionCounter = 0; positionCounter < 29; positionCounter++) {
lcd.scrollDisplayLeft();
delay(500);
}Program Explanation
Library and Display Setup:
#include <WiFi.h>
#include <Wire.h>
These lines include necessary libraries for Wi-Fi, communication, networking, and controlling the LCD display.
LiquidCrystal_I2C lcd(0x27,16,2);This initializes an LiquidCrystal_I2C object named lcd. It specifies the I2C address (0x27) and the LCD’s dimensions (16×2).
Server and Wi-Fi Configuration:
const char* ssid = "SSID"; // Wi-Fi SSID
const char* password = "PASSWORD"; // Wi-Fi password
Here, an AsyncWebServer object named server is created to handle web server functionality on port 80. The ssid and password variables store the Wi-Fi network credentials.
const char* PARAM_INPUT_1 = "input1";This creates a constant variable PARAM_INPUT_1 that will be used later.
HTML Template:
<!DOCTYPE HTML>
<html>
<head>
</head>
<body>
<p>
<marquee>Smart Notice Board</marquee>
</font>
</p>
<center>
</form><br>
</center>
</body>
</html>
)rawliteral";
This defines an HTML template named index_html. It creates a web page with a form where users can enter text to display on the notice board. The page includes a title and some basic styling.
Error Handling:
The notFound function is used to handle 404 (Not Found) errors that occur when the server is unable to locate a requested resource.
Setup Function:
Serial.begin(115200); // Start serial communication for debugging
lcd.init(); // Initialize the LCD
lcd.clear(); // Clear the LCD
lcd.backlight(); // Turn on the LCD backlight
lcd.setCursor(0, 0); // Set the LCD cursor position
lcd.print("Smart Notice Board"); // Display "Smart Notice Board" on the LCD
WiFi.mode(WIFI_STA); // Set Wi-Fi mode to station (client)
WiFi.begin(ssid, password); // Connect to the specified Wi-Fi network
// Check if Wi-Fi connection was successful
return;
Serial.println();
Serial.println(WiFi.localIP()); // Print the ESP32's IP address
// Configure server routes for handling web requests
// Handle user input and update the LCD
String message;
String inputParam;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(message);
else {
// Send a response back to the user
server.onNotFound(notFound); // Handle 404 errors
server.begin(); // Start the server
The setup function is where the program’s basic initialization occurs:
- Serial communication is started for debugging purposes.
- The LCD is reset, cleared, and the backlight is activated. On the LCD, the statement “Smart Notice Board” is shown.
- The ESP32 is set up to connect to the selected Wi-Fi network. If the connection fails, the message “WiFi Failed!” is printed.
- Server routes are defined to handle different web requests:
- The root (“/”) route serves the index_html template when users visit the root URL (“/”).
- The “/get” route handles user input and updates the LCD display accordingly.
- The notFound function is configured to handle 404 errors when requested resources are not found.
- The server is started with server.begin().
Loop Function:
lcd.scrollDisplayLeft(); // Scroll the text on the LCD to the left
delay(500); // Delay for half a second between scrolls
In the loop function, the code continuously scrolls the text on the LCD to the left for visibility. It shifts the displayed text to one position left and then introduces a delay of 500 milliseconds between scrolls.
In summary, the Smart Notice Board project makes use of the ESP32 microcontroller to enable remote message display on a scrolling LCD display. It gives a modern and effective alternative for sharing information without the need for traditional notice boards.
