Top 10 Arduino Projects On Instructables till 2018 (Best Ever)
Are you looking for Top Arduino Projects to make in 2018? Then without a doubt, Instructables.com is the best place for you to get started. Here is the list of top 10 Arduino projects on Instructables till 2018 (Best ever)
This list contains details of the all-time top 10 Arduino projects on Instructables. Now, this list is just our opinion made out of more than 1000 Arduino projects available on Instructables. But believe me, projects in this list are selected very carefully by keeping in mind each and every aspect.
NOTE: Please keep in mind that these projects are selected mainly on the basis of creativity and application And not merely on the basis of complexity involved. So when you go through these projects, don’t judge on the basis of difficulty only. These projects will give you a good idea of Arduino’s never-ending applications. Link to each project is given below the respective project’s summary.
Just try to make these projects to unleash that creative engineer within you!
Top 10 Arduino Projects On Instructables:
10. Arduino sunflower:
Arduino Sunflower – an Electronic Sundancer
OBJECTIVE: To build an Arduino-Servo controlled mechanism that follows the sun as it moves in the horizon.
Solar Panels can be attached to the front so that maximum sunlight get absorbed by them at any instant. Since Arduino-Sunflower acts like a real Sunflower in presence of sunlight, it is called an electronic Sundancer!
This project was posted by Elecrow on Instructables.com
Components you need for this project are:
1) Arduino Board
2)  LDR(Light dependent resistors) X 4
3) Connecting Wires
4) Linear Potentiometer X 4
5) Base Shield For Arduino
6) Cardboard
7) Foamboard
8) Stick
9) Servo Motor
Link to the project site is given below:
Arduino Sunflower
9. Arduino Mini CNC Plotter Machine From Dvd Drives
OBJECTIVE: To make a simple CNC Plotter Machine using 2 DVD drives, 2 Mini Servo and Arduino.
This project was originally posted by Ardumotive_com  on Instructables.com and is an updated version of this CNC Plotter.
1)  Arduino Board
2) Breadboard for connections
3)  L293D ICs Motor driver x 2
4) Mini Servo Motor x 2
5) DVD/CD Drives x 2
6) ATmega328p (with Arduino Bootloader)
7) 28 pin DIP IC Socket
8) 16MHz Crystal Oscillator
9) 2x 22pF and 1x 100nF capacitors
10) 10K resistor
11) USB to Serial adapter
12) Prototyping PCB Circuit Board Stripboard
13) 2pins Screw Terminal Connector x 4 (or 2x 4 pins Screw Terminal Connector)
8. Bubblesteen Bubble Machine
OBJECTIVE: To build a mechanism using Servo motors and Arduino that automatically creates the soap bubble after a certain time period.
Two servo motors are required to build this project in order to get a perfect arm movement.
 Electronic Components you need for this project are:
1) Arduino Duemilanove
2)  Duemilanove Motor Shield
3) Connecting Wires
4) D.C Motor(3v-12v)
This Instructable is posted by belliedroot  and link to that project is given below:
7. Somatosensory Quadrocopter Module
OBJECTIVE: To control a Quadcopter using hand movements. Actually, Arduino nano attached to the glove is controlling quadcopter’s remote control which ultimately controls the quadcopter.
This project was posted on Instructables by NFU_Dream_Maker. Link to this instructable is given at the bottom of this project.
1) 4 Servo Motors
2)  Arduino Nano and Arduino Mega
3) Connecting Wires
4) Quadcopter its Remote controller
5) MPU6050
6) NRF24l01 x 2
7) MP2307
8) TP4056
9) 2mm iron shaft x 4
6. Secret Knock Detecting Lock
Secret Knock Detecting Lock using Arduino
OBJECTIVE: This “Secret Knock Detecting Lock” opens the lock when a secret knock is given on the door. One can change the knock pattern according to his/her need by just pressing the programming button and recording the knock. Up to 20 knocks pattern can be stored in this version of the code.
This project was posted on Instructables by Grathio
Link to the project page is given below:
5. Rubik’s Cube Solver
Rubik’s Cube Solver using Arduino
OBJECTIVE: This robot, made of 2 Servo Motor and Arduino can solve Rubik’s cube within 20 minutes. You can do some adjustment in code and mechanism to decrease this time.
This project was posted on Instructables.com by matt2uy. Link to this instructable is given at the bottom.
1) 2 Servos
2)  Arduino Uno
3) Connecting Wires
4) wooden skewers
5) thin plywood
6) wooden wheel
7) Resistors
Software:
– Arduino IDE – (Algorithms in C++)
– Python 2.7+ and Tkinter – (GUI)
– Pyserial
Rubik’s Cube Solver
4. Time Machine Glove
DIY time machine glove
OBJECTIVE: To make a glove using Arduino that can control time! Well, this glove does not stop time in reality but makes it appear though. It makes the speed of the objects to appear slow to our eyes.
Mad Gyver demonstrated his “TIme Machine Glove” by freezing a fan, drill and T.V screen in this video.
1)  Arduino Board
2)  DC-DC Boost Converter
3) Accelerometer
4) Potentiometer
5) Lithium Battery
6)  Connecting Wires
7) 10k and 100-ohm Resistor.
8) LED 100 Watt (white)
9) Mosfet
10) Glove
Time Machine Glove Using Arduino
3. Ball And Plate PID Control
Ball and Plate Arduino PID control
OBJECTIVE: To make a Ball-Plate PID control using Arduino.
Watch this video to see this “Ball And Plate PID Control” project in action.
This project was posted on Instructables by DavidH334. Link to this instructable is given at the bottom.
1. Arduino Board
2. Digital Servo Motors (HS-422 ECO) x 2
3. Wire Resistive Touchscreen (7″) x 4
4. Real-Time Module DS1307
5. Wii Nunchuck kit
6. IR remote kit
7. Breadboard
8. Connecting Wires
Ball & Plate Arduino PID Control
2. Tree Climbing Robot
Tree Climbing Robot using Arduino
OBJECTIVE:   Yes this robot can climb trees! and that’s why this project is one of the most popular projects on Instructables.
Watch this video to see Tree_Climbing_Robot in action!
This project was posted on Instructables by ben_k. Link to this instructable is given at the bottom.
Tree Climbing Robot
1.  Air Guitar Using Arduino
OBJECTIVE: Now you don’t need a real guitar to play music! This Air guitar is a perfect replacement for an actual guitar or maybe not if you only knew how to play this air guitar!
This Arduino based Air guitar is made by team Jell
Watch this video to see “Air-Guitar ” in action!
1) Arduino Board
2) Accelerometer
3) Ultrasonic Sensor
4) Connecting Wires
5) Potentiometer( bw 1kohm-1Mohm)
6) LED’S
7) 3.5 mm female jack
8) Battery(9v)
8) Resistors (10k), capacitor(10uF)
Personal Favourite 🙂
** LED Cube (8x8x8) Using Arduino
This is one of the coolest projects you can make using Arduino whether you are a beginner or expert. It may seem complicated at first but believe me, this project is very simple. You just have to make all connections properly and ensure that each and every LED is working. Then just burn the given code to your board and you are good to GO!
1) Blue LED x512
2) Arduino Board
3) 100-ohm Resistor x64
4) Connecting Wires
5) PCB Board
6) 3x status LEDs
7) 3x resistors for the status LEDs
8) 74HC574 x 8 ICs
9) PN2222 transistors x 8
LED CUBE (8X8X8)
Similar Post:
One comment
  1. Thanks for sharing excellent informations. Your web site is so cool. I am impressed by the details that you have on this website. It reveals how nicely you perceive this subject. Bookmarked this web page, will come back for more articles. You, my friend, ROCK! I found just the information I already searched all over the place and simply could not come across. What a perfect website.
