Top 10 IoT (Internet Of Things) Projects You can Make in 2018
IoT Motion Controlled Servos
Are you looking for Top IOT Projects to build in 2018? Then you are at the right place! Here are the Top 10 IoT (Internet Of Things) Projects You can Make in 2018.
IoT is one of those sectors which is going to transform into a multi-trillion dollar industry in near future. Hence learning IoT(Internet Of Things) can add more value and improve your creativity skills. This list contains details of the all-time top 10 IoT projects. Before you go through the post I want you to know that projects listed below are selected very carefully by keeping in mind each and every aspect.
NOTE: Please keep in mind that these projects are selected mainly on the basis of creativity and application And not merely on the basis of complexity involved. So when you go through these projects, don’t judge on the basis of difficulty only. These projects will give you a good idea of IoT(Internet Of Things) applications. Link to each project is given below the respective project’s summary.
Just try and make these projects to unleash that creative engineer within you!
Top 10 IoT(Internet Of Things) Projects :
10. Arduino IoT Robotic Arm:
ARDUINO IOT ROBOTIC ARM
OBJECTIVE: To build an IoT based robotic arm having 5 Degrees of freedom( Including gripper).
Arduino is used as a control device for this robotic arm. Control Interface is built in Blynk app and forward kinematics are implemented in Matlab.
This project was posted by Elecrow on Instructables.com
Electronic Components you need for this project are
1.Arduino Board x 1
2. Led’s x 2
3. Resistors, 100 ohm  and 150 ohm  x 2
4. Servo motors x 1
5. 5V charger, min 2.5 A x 1
Link to the project site is given below:
9. IoT-Toy-Trafficlight
OBJECTIVE: To build an IoT based Trafficlight light look-alike project, controlled by a smartphone using wifi.
There are multiple modes available including police-mode, a moodlight, and a sleep timer.
Electronic Components you need for this project are:
1)  Wifi Module ESP8266
2) Power Bank
3)  USB Cable
4) Cables for Connection
5) PCB Board
8. Raspberry Pi & Arduino Wooden Chess Computer
OBJECTIVE: To build an auto position suggesting Chess board using Raspberry Pi and Arduino.
This project was made by Maxchees42.
You can watch this video for instructions.
R-A Wooden Chess
7. Wolf : IoT Multi-Terrain Quadruped
OBJECTIVE: To build a quadruped robot using Raspberry Pi which can easily transform between walking mode and rover mode (aka wheel traversing).And that’s why it is called the Multi-Terrain Quadruped.
This project was posted on Instructables by HuskyRobo. Link to this instructable is given at the bottom of this project.
1) Raspberry Pi 2
2)  Pi Camera Module
3) Mini-Maestro 18 channel USB Servo Controller
4) Raspberry Pi Motor hat
5) Pololu Maestro 75:1 DC Micromotor x 4
6) USB Wifi Adapter
7) High Torque Servo x 12
8) 6v Battery
9) Anker Astro E1 5200mAH.
10) MicroServo x 2
6. Electroic door lock
OBJECTIVE: To build an IoT based advance electronic door having following features:
  (as stated in project website)
  • Unlocks whenever authenticated person walks by.
  • Automatically lock a deadbolt when the door closes
  • Report all “access granted/denied” and “door open” events to the Internet.
  • Lock still needed to be operable by school housing administration
  • Lock must be operable manually with a key from the outside and fingers from the inside (no “push to exit” button) ” source: speedy signals
this project was originally posted on speedy signals.
Link to the project page is given below:
Electronic Door Lock
5. IoT Motion Controlled Servos
OBJECTIVE:  These IoT Servos are motion controlled that mimics our hand movements and displays colors based on finger positioning over the pad.
This project was posted on Instructables.com by  . Link to this instructable is given at the bottom of this project summary.
1. Raspberry Pi – I am using a V1 Model B+
2. Leap Motion Controller
3. 5V Power Supply
4. I2C Enabled PWM Driver
5. 4 x Micro Servos
6. On-Off-On Slide Switch
7. Small Push Button
8. RGB LED + 2 x 470 ohm resistors
9. Hook Up Wires
10. LEDs and Current Limiting Resistors
11. Power Jack, Switch, and Cable
Software:
1. PubNub
2. Java SE
3. PubNub Java SE SDK
4. Java IDE
5. Leap Motion Visualizer and Java SDK
6. Project Source Code Repository
4. Windows IoT: Facial Recognition Door
facial recognition door
OBJECTIVE: IoT based Face Recognition Door.
This “Facial Recognition Door” is built using a Raspberry Pi, basic Webcam, and an internet connection. Whenever control device recognizes the visitor, this door unlocks!
Watch this “Facial Recognition door” made by windows IoT team in action:
3. DIY Life-Size Phone Controlled BB8 Droid
BB8 Droid
BB8 Droid
OBJECTIVE: Building a real-life Star Wars BB8 Droid.
Watch this video to see  “DIY Life-Size Controlled BB8 Droid”  in action.
Ball & Plate Arduino PID Control
2. Mark Zuckerberg’s AI- JARVIS
OBJECTIVE:   Requires no explanation, just watch the above video!
Link to the video source is given below:
Mark Zuckerberg’s AI-JARVIS
1.  Zelda Ocarina Controlled Home Automation
OBJECTIVE:   This Home automation project video will blow your mind! Everything around you, even your car lock system can be controlled by a Zelda Ocarina.
This project was made by Allen Pan
In this video, he demonstrated his home automation system based off the Zelda series using the ocarina from The Legend of Zelda: Ocarina of Time.
Link to the project video is given below:
Similar Post:
2 Comments
2 Replies to “Top 10 IoT (Internet Of Things) Projects You can Make in 2018”
  1. I like what you guys are up also. Such intelligent work and reporting! Carry on the excellent works guys I?¦ve incorporated you guys to my blogroll. I think it’ll improve the value of my site 🙂
%d bloggers like this:
