Measuring Distance Using Ultrasonic Sensor And Arduino
In this project we are going to measure the distance using an Ultrasonic sensor and then print it on LCD.
LIST OF COMPONENTS REQUIRED:
  1. Arduino
  2. 1602 LCD Screen (16 x 2 LCD)
  3. Jumper wires
  4. Arduino program in computer
  5. 220ῼ resistor
  6. 10k potentiometer
  7. Breadboard
  8. Ultrasonic sensor HC04
CIRCUIT DIAGRAM:
CONNECTION
The circuit:
  1. LCD RS pin to digital pin 12
  2. LCD Enable pin to digital pin 11
  3. LCD D4 pin to digital pin 5
  4. LCD D5 pin to digital pin 4
  5. LCD D6 pin to digital pin 3
  6. LCD D7 pin to digital pin 2
  7. LCD R/W pin to ground
  8. 220 ῼ resistor: lcd pin 15 and ground
  9. Potentiometer wiper to LCD VO pin (pin 3) and ends to +5v and ground of arduino kit
  10. LCD pin 16 to ground
  11. Trig pin of the sensor to 9
  12. Echo pin of the sensor to 10
  13. Gnd of the sensor to ground pin of arduino.
  14. VCC of the sensor to 5V pin
CODE:
#include <LiquidCrystal.h>
  #define trigPin 9
#define echoPin 8
float duration;
float Inches;
float Cm;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
pinMode(trigPin,OUTPUT);     //sets trigpin as output to send ultrasound
pinMode(echoPin,INPUT);      //sets echopin as input to receive ultrasound
 Serial.begin(9600);                  //sets 9600 as baud rate
  lcd.begin(16, 2);                      //enable 16 columns and 2 rows in the lcd
void loop()
  lcd.setCursor(0,1);                      //sets cursor at 1st row and 2nd coulumn
  digitalWrite(trigPin, LOW);   //sets trigpin to LOW so that it do not emits ultrasound
                                                          //  initially
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);                  //sets trigpin to HIGH state to emit ultrasound
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);                        //reads the travel time of the pulse
  Inches = microsecondsToInches(duration);         //function
  Cm = microsecondsToCentimeters(duration);     //function
  lcd.setCursor(0,0);                                                        //sets cursor to initial position
  lcd.print("INCHES");
  lcd.setCursor(7,0);
  lcd.print(Inches);
  lcd.setCursor(0,1);
  lcd.print("CM");
  lcd.setCursor(7,1);
  lcd.print(Cm);
  delay(100);
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;   /* sounds travels at the speed of 1130 feet per second. There are 74.16 microseconds per inch. The time that will  be  received is of full journey of ultrasound i.e. forward and backward. So to calculate the distance we have to divide total time by number of microseconds per inch i.e. 74. We have to further divide it by 2 in order to calculate the distance of   only forward path and not the total distance*/
long microsecondsToCentimeters(long microseconds)
 return microseconds / 29/ 2;  /*Speed of sound is 340m/s. So it takes 29 microseconds to  travel 1 centimeter length of the path.All the working  is same as explained in calculation of inches*/
WORKING:
When the trigpin of Ultrasonic sensor is HIGH for 10 microseconds, it emits an ultrasound which travels through air at the speed of 340m/s. If an object is placed in its path than it will be reflected back to the sensor. Echopin receive the ultrasound that is reflected by the object and thus calculate the time of return using code.
NOTE: code is explained line by line by using extensive comments.
